Weber is in!! Some Pics.: =]
11 following
dragn37
ohk, well i got my weber here today, and i have no idea what needs to be left/ or disconnected .
Also, what do you do to plug those exhaust holes off with??
so basically im just asking 2 questions,
1. What do you keep and what do you get rid of? pics of b4 and after???
2. How/What do you use to plug the exhaust holes.
I'm doing this right now, sooo any quick help is greatly appreciated. thanks.
Post was last edited on Jul 10, 2009 01:55. Edited 1 time.
nc4life's avatar
nc4life
Well pretty much all the emssion crap on pass side fender well. All those vacum lines can go just make sure you keep the one for the dissy and plug any extra ones. That wire harness can go just go through it and keep the wires for your wipers if you still have them. Do you have auto or manual tranny? As far as the exhaust holes most people put on a new header so I'm not sure what you can do. Maybe figure out the size hole and thread and get some plug for them. Maybe someone else wil chime in with more info and pics.
pimpz26's avatar
pimpz26
This is what I did with my three exhaust pipe. The one that goes to the top of the exhaust manifold got cut off and folded over where it bends to go under the dizzy, the the greatest solution, but it works and doesn't leak. The other two got unbolted down at the bottom of the exhaust manifold and removed. There is a support plate that hold these pipes, it can now be used as a block off plate on the exhaust manifold. There is four holes in this plate, the holes diagonally accross from each other are spaces perfectly to be used as a block off plate. Mazda gives you parts to use, LOL.
And yes, remove everything, vac. lives, wires, computer. If it's attached to the stock carb, it goes in the trash. I had a hard time believing this myself, but it's easy.
Here's my block off plate, inside green circle. Power steering hose is in the way of a good picture. It used to be attached where the square is.
My drawing here. If you were to use the green holes, cut the plate at an angle, then it fits alot better.
Sorry for being so long winded.
h2omelon(nick)'s avatar
h2omelon(nick)
For the upper holes in the manifold you can use some 14x1.5 bolts available at any hardware store.
dragn37
Thanks soo much. Been working on it for a couple hours, its easier then i thought!
pimpz26's avatar
pimpz26
Never thought about trying to get the threaded portion out of the manifold. I tried to find some metric caps for them, I couldn't find any so that's when I decided to cut and fold the pipe. I think I'm going to the hardware store tommarrow.
dzminiz's avatar
dzminiz
I wanna get rid of that damn nest!!!! I needs me a carb & header.
Whered ya get ur carb at Dragn?
90-b22dawg [andrew]'s avatar
90-b22dawg [andrew]
ebay has them all the time
sparage's avatar
sparage
On the manifold I plugged the holes with caps from a hydraulic and gasket place. Same thing I use to cap off cylinders and stuff.
dragn37
Hey!!! i got it in, about 2 hours/3 hours of work, but its in thier, running BETTER then EVER. Man this thing makes the truck feel so different. The power increase is a dramatic NOTICEABLE increase, i LOVE IT.
<img src="{SMILIES_PATH}/icon_biggrin.gif" alt=":D" title="Very Happy" /><!-- s:D -->
some pics:
I still have some things to remove/ e.t.c. But shes in thier and running awesome!!! The Weber really woke this truck up big time. Couldnt of spent the money better. Now time for some pacesetters hahaha <img src="{SMILIES_PATH}/icon_cool.gif" alt="8)" title="Cool" /><!-- s8) -->
And DZ here you go man:
