I'm wanting to buy one soon, and see some good prices on ebay and other sites I found on google.. but just wondering if any of you know certain specs or anything to look for when buying one to make sure itll be good quality. Let me know where you all got yours, thanks!
dragrocker
i just have some cheap one ..not sure who makes it lol. but it works fine.
whynotfab
Is it similar to this?
dragrocker
actually i think that may just be it
TC29720
Go to your local Northern tool, i thnk its the one in the pic. Works just as good as the expensive ones
streetsweeper1
get a pipe masters (tubing contour measuring tool) mark the line around the tubing,cut off the end with a plazma cutterand then use a cone grinder attachment to finish it off
DawgsledMazda
the one in the above pic is a piece of crap. the part that holds the tube is thin and will bend over time. I use a notcher every day and went thru one of those very quickly.
I got the speedy notcher from speedway motors. its only 100 bucks and worth every penny.
whynotfab
Hey Mike do you think it would work if I rarely use it compared to how much you use tube?
tandem
You might want to check Harbor Freight Tools. I think I've seen them there before and their stuff is fairly inexpensive.
streetsweeper1
Tubing notchers are only good for certain angles. the best way to fit tubing is to use a pipemaster. Tubing notchers are just for the cutting part of the job. a plasma cutter is the fastest way to cut the tubing. unless you have a $2500 power speed notcher. I like to finish off the cut pipe with cone grinders. But hey, 6 eggs or a half dozen of the other.
