Got going on the front brake up
First up was change out the master to a 1" unit & @ the same time a double diaphragm booster
truck action
At the same time I made a polished plate to cover damage to the Line-X under the clutch master
truck action
Next the new mounting bracket into place
truck action
Problem one, clearance @ the mounting tabs
truck action
Removing 5mm was the fix. Though after doing this I thought I should have split the difference between the caliper & spindle.
truck action
Once all was in place ,problem #2 , the outer pad made contact with the hat. A little trimming took care of that
truck action
Also had to install longer wheel studs due to the hat thickness of 1/4",like a wheel spacer,moves the rim out,& only leaves 1/4"of thread
truck action
Post was last edited on Jul 20, 2008 04:54. Edited 2
times.
