BEST WAY TO DROP STOCK MAZDA???
sahankaface203@yahoo.com's avatar
sahankaface's avatar
sahankaface
I AM STARTING MY PROJECT SHORTLY AND I WANT TO DROP IT WHAT IS THE BEST WAY TO DO THAT WITHOUT KILLING THE RIDE I AM REPLACING ALL BUSHINGS ,BALL JOINTS AND SHOCKS TO (WHAT ARE THE BEST SHOCK SET UP TO GO WITH???) ANY INFO WOULD BE GREAT I AM NEW AT THIS.THANK YOU
slamditbig's avatar
slamditbig
if you are lowering and want a good ride bag it, cause once you start it'll never be low enough
sahankaface
I KNOW IF I HAD THE MONEY IT WOULD OF GOT BAGGED LAST WEEK BUT I DONT SO I WANT TO GO WITH A DROP FOR NOW SO IT DOESN'T LOOK SO CRAZY AT THE HEIGHT IT IS NOW
MJ
mr. jaun durfle
I lowered mine in the front by cranking the torsion bars... I dropped the front about 2.5" and use Doetsch Nitrogen Drop shocks. In the rear I lowered it 5" by using 3" blocks and taking out two leaf springs. Keep the top leaf spring and the short "overload" spring to do this... it lets the rear "sag" about two inches. I have Doetsch Nitrogen Drop shocks in the rear as well. I ordered the shocks from Can Do Specialties online... the front shocks are the M4028G's and the rears are the 4095G's. The ride isn't cadillac plush, but it is much better than the typical lowered truck you see with stock shocks. Good luck with your truck.
sahankaface
thanks any other ideals ?
sahankaface
snoplow
depends on whel size too. i ran 185/60/14 on the stock chromies. and 195/50/15 on my pathies. i reindexed my torsions, flipped the bj's and in the rear ran main and overload leafs and 5" blocks. but i did notch my frame and built new lower shock mount plates for the rear. relocated the top mount point to my notch. i tucked my 15's! but it did ride ruff.
sahankaface
I AM TRYING NOT TO NOTCH IT RIGHT NOW I WILL WHEN I BAG IT
Post was last edited on May 15, 2010 02:50. Edited 1 time.
sahankaface
DO YOU GUYS THINK THESE ARE ANY GOOD
kevintothej's avatar
kevintothej
Nothing wrong with drop spindles except you have to run a 16" or bigger wheel. If you are planning to bag it later on you will not really need them unless you are going for 20's or bigger.
