Winter prep...northern guys help please
25 following
draggingtb@yahoo.com's avatar
draggingtb's avatar
draggingtb
I'm about to take a long ass trip north for a few weeks in my daily. Living in FL, there's not much winter prep involved obviously. But I'm going to be going to snow and all. Other than basic trip maintenence, what kind of special prep should I take care of to handle the temp changes and what not.
GB
Gangsta Boogie
just put your stock wheels on, if you dont have them anymore, you can get cosmoline in a spray can and spray it on your wheels. it protects agaisnt anytype of corrosion and wipes right off with kerosene. its commonly used to store machine tools.
draggingtb's avatar
draggingtb
I already have stocks. I'm more worried about needing a different coolant, if i should swap to a different tire than an all season uniroyal, and things like that.
RobbyDizzleonDubs's avatar
RobbyDizzleonDubs
hahahahahahahahahaha. you don't need a different coolant. all season will be fine. As long as you don't let your tires spin in the snow you'll be fine.
draggingtb's avatar
draggingtb
ok, just wanted to make sure. i've never driven up north. only lived in FL. a few people tried telling me before that you need a lot of different shit up north, coolant, etc. so i figured i'd ask before i did anything.
lowdyme's avatar
lowdyme
umm the only special thing i might suggest is if your on air you get some air brake antifreeze i think thats the name if not in the am when you go to lift up your truck it either wont or pick up and drop right back down
onelow96cs's avatar
onelow96cs
bring some kittie litter,salt, and a shovel... Just incase you slide off the road.
st Ranger's avatar
st Ranger
Weight in the back and winter tires on the rear will help if you plan to go in the snow, and believe me.
blackice's avatar
blackice
how far notrh do you plan on going exactly?
ShaveDnFlamed99
a few sand bags over the axle helps alot air brake anitfreeze is a must for bagged trucks up here
