is a bag this crooked normal?
18 following
bradremy@cebridge.net's avatar
IB2LOUD's avatar
IB2LOUD
I used the SD cups and they only went in one way, and i made the hole for the air line go towards the rear of the truck...did i do something wrong
91 drggn dime's avatar
91 drggn dime
no, here is mine with slam RE7 and SD cups.
IB2LOUD's avatar
IB2LOUD
these are contitech 2ply 2500 bags
MoneyMike2
looks normal for the front of an s10
complexdesigns's avatar
complexdesigns
Looks like a Ranger too
IB2LOUD's avatar
IB2LOUD
so this won't hurt anything? does it hurt for the bag to rub itself
91 drggn dime
no. you will also see over time when the truck is laid out, your bag will overlap and lay on the LCA, doing this will leave a little rub mark on it. Mine do it when i drag b/c i'm laid out, but it wont put a hole into it, it just shows a noticeable wear mark.
tofnlows10's avatar
tofnlows10
nope..
1 LoWfUKn RaM's avatar
1 LoWfUKn RaM
too me imo looks a lil too crooked just by looking at ur lower arm spaced away from the frame dosnt look like is at full lift and thats way too crooked for the lift u got in the pic..the other pic is a lil higher the one with the 2600 bag u an tell by looking at the lower arm spaced away from the frame...
fatboysS1O's avatar
fatboysS1O
on a s10 there gunna be crooked like that. thats the way my conti's looked when i had them on my s10. conti's have a lil more play in them then the slams. so there gunna overlap a lil more and more over time. i use slams now and they're stiffer than the conti's so they'll still sit at a angle but the bellows barely/dont touch.
if anything maybe push the cups a lil closer to the inside of the frame. maybe thatll straighten them up a lil bit.
s10
last post by baha +1y
