how to get this color?
ricky@whynotfab.com's avatar
whynotfab's avatar
whynotfab
I was just wondering if any of you paint guys know the best way to get this color, maybe a little brighter, I would want it good quality so it seals.. would I buy light grey sealer primer and mix the right color blue in, and theres my grey and blue.. or, use white primer sealer and mix light grey in some, and the blue into more.. seems thatd turn out brighter, but i dont know much about all of that. what reducers and supplies would be needed? maybe a price range also.. and a good affordable gun so I can practice myself. thanks guys heres a rough draft with a color thats kinda close..
DodgeRT's avatar
DodgeRT
do not mix sealer with base coat
DodgeRT's avatar
DodgeRT
if you want a light shade effect use white sealer,if you want the basecoat darker use a black sealer,any HVLP gun you can use(High Volume Low Pressure),what brand of paint you want i.e. HOK,Dupont,PPg,Auto Air Color(Waterbased)
DodgeRT's avatar
DodgeRT
IM me if you need any more help,i'll help you with the best i can
DodgeRT's avatar
DodgeRT
supplies:Auto Air color is waterbased which you don't really need much supplies,they did an article a while back in MT about it,AutoAirColors.comcheck up on what you wanna go with
whynotfab's avatar
whynotfab
thanks for the quick help Josh, which of the brands would you recommend? like I said i dunno much about it.. trying to learn and you seem to know a lot so let me know! maybe i could pick a gun up on ebay, if you see any good deals with the right specs let me know also.
reaperride1
are you trying to get your primer this color or are you looking at finishing you truck out in this color?
whynotfab's avatar
whynotfab
primer for now
whynotfab's avatar
whynotfab
also im really confused how id tape it off to do the black pinstripe like that.. what steps do i do to get the black stripe, then the 2 other color 2 tone?
bbb's avatar
bbb
Spray the black first then lay out the stripe with tape then spray the bottom ,tape down from black stripe then spray the top then unmask everything.Don't forget to sand in between every color.Hand sand with 320 or 400 nothing rougher or smoother than that is nessacery.Use white sealer ,I'm not sure who makes it but someone sell tint for sealer, it comes in a kit with like 5 differant colors.
