White god damn smoke..
15 following
CM
c mau
alright as u know i got my fuel cell all hooked up with the msd inline fuel pump...but i drove it today and it jsut started puttin out wit smoke even at idle!!
nehelp u guys out there got..
eksessivdragger's avatar
eksessivdragger
mine did that right after i swapped motors and had oil all over and in the header. It was just burning off the oil. might be ur problem.does it continue to do that?
CM
c mau
alright..idk it just like is white smoke..when i first start it it wont do it but if u rev it like once or twice itll start puttin out white smoke..then even at idle it will keep doin it..and i checked my oil..shes full..
laynwindows
maybe you have too much oil in there
CM
c mau
so should i jsut let it run for a while??
shvd64cdy's avatar
shvd64cdy
YOUR RUNNING RICH!!!! you have too much fuel going in. The msd pump puts out substantially more psi and fuel volume. Put a regulator on the pump end and you should be just fine.
wht01ranger's avatar
wht01ranger
hey bro are you sure it is white?
white smoke is usually coolant burning off, which means you have a cracked head mostlikely or a blown head gasket
bluish tint smoke is oil
and black smoke is excess fuel, or running rich
CM
c mau
where do i get a regulator from??
CM
c mau
and if i had a blown head gasket i would be leaking oil wouldnt i??
wht01ranger
not always
