head light and directional problem
projectneverdone
Im having and issue with directionals and head lights as well. When ever i put my left side directional on it works fine then i turn head the lights on the directional stays on until i shut the switch back to middle position. the right side directional blinks real fast like the bulb is out. Ive replaces the flasher under the dash. Still same deal. IM lost on this one any ideas?
framescr8pintoy's avatar
framescr8pintoy
need more info.... do you have all the stock lights still. or have you shaved the corners or bumpers, added led's etc.
projectneverdone
yeah all the lights are stock nothin has been shaved. it just happen allof a sudden.
projectneverdone
any idea guys
projectneverdone
aight so ive changed the flasher underneather the dash as well as the tail light relay on the fuse panel underneath the dash i changed the wiring harness in the tail lights. I still have the LS directional on when i turn the lights on. Also when i turn the parking lights on i have nothing in the rear (but every thing else works. blinkers brake lights) The parking light on the LS very very dim, right side is normal. Any idea what it could be?
kdcgrohl's avatar
kdcgrohl
front and back?
projectneverdone
i have parking lights on the right side front which is normal. On the left side front very very dim hardly anything. The back theres no parking lights. But when the lights on and the directional is on is on in the rear and front. Try to explain it as easy as possiable. Thanx for even readin it man. I want to get to Low rollers next weekend in NJ. Soo well see.
yodaforce's avatar
yodaforce
First off, it sounds really confusing. When I put my truck in reverse, my driver front parking light comes on and I get people telling me all the time how "You're pass light is burnt out..." but electrical problem suck and it doesn't bother me.
As for your troubles, sounds to me like there could be a problem in the switch. If everything is stock and you have replaced bulbs, flashers, etc... that leads me to believe it is in the switch. It's a tough fix, easier to get another switch and try it out. And I mean the whole arm.
coolrollawgn
sounds like a ground problem. what year is it? i have a switch i think it is an 89 style sell it cheap if it is the one you need.
projectneverdone
im gonna run to the junk yard tomrrow done the street from my house theres a switch in it. Ill give it a shot man. Its eaither that or a ground some wher ei got he interior ripped apart now soo mine as well at this point. Thanx alot guys i appriciate. Can even tell how many times ive just wanna put the for sale sign on it because i get soo frustrated.
