Electrical Problem
Electrical Problem
hotlavaxb2089
I have a paracidic drain on my battery of like 5.5 amps and i have been trying to figure it out. I have traced it down to a solid whit wire that comes out of the fuse box under the hood. The fuse is the AM1. What does this go to? i am assuming to goes to the interior of the cab cause there is a plug on the left fender that when i unplug it the drain goes away so it is somewhere in the cab i assume.
Does anyone know anything about this or maybe a wiring dagram that is better than the shitty Haynes manual.
This thing has me stumped
slammedtoys's avatar
slammedtoys
try going to your local Napa. I was having an electrical problem and just so happened to stop by there and they were able to give me a wiring diagram that was a 2309523423 times better then any book i had access to.
truck action's avatar
truck action
I have the 1988 Truck& 4 Runner electrical Wiring Diagram book from Toyota( should be the same for 87) you can get this from Toyota . That white wire goes from the ignition s/w to the fuse,to the battery,& from there to the starter
Send me your e-mail I'll send a cody of this page to you
chinkychris
check the main connection at the fuse block. (Main from batt)
You may find something loose...I speak from experience!!
hotlavaxb2089
nothing is loose and i know cause i have had everything apart and back together more than once now
hotlavaxb2089
Well I found out what the problem is. The Choke heater is what was pullingthe 5 amps. Now i just have to find the part and oriellys and autozone cant even get it.
Anyone know where i could get one
chinkychris
Past a pic of what it looks liek and message me....I might have one
hotlavaxb2089
i will send a pic tonight, it is the plastic bowl looking thing on the back of the carb
And fyi toyota wants 171.00 for this part.
There is no way i am going to pay that much I have decided if i cant find the part i will buy a weber carb.
truck action
Yeah, a lot of the special switches & controllers can only be got @ the dealer & are always a brunch of money. I've had to buy a few of them!!!
hotlavaxb2089
here are the pics of the part that is draining the battery
