bed removal/ slight build thread
hampton123
Ok so I noticed gas leaking as I was filling up on my way to work yesterday. Looks like its just a crack in the filler hose but, while i'm replacing that might as well do all the rubber hosing and fuel filter too. Figure it would be easier to remove the bed than t work around it. Any tricks to these beds or is it just unbolt and heave ho? Also on a side note found the source of that nasty sound in my exhaust.
Think its time for a new one and, might as well upgrade since it needs to be replaced anyways!
Post was last edited on Sep 02, 2010 11:52. Edited 1 time.
slow50
yup just un bolt it 4 on each side. then you gota undo a couple hoses from the filler or maybe just unbolt the filler from the bed itself dont remember. and unplug the tail light wires.
hampton123
yeah It unbolts from the bed, but the darn things are a discontinued product so idk how I'm going to fix it yet
slow50
what do you need? i removed my stock gas tank i still got some of the stuff. you can get new ruber hose doesnt have to be from the dealership.
hampton123
I'm not really sure what all I need yet, but once I get my bed off I will probably just replace all the rubber.
hampton123
So I found my fuel leaks
filler hose
fuel line
figured I might as well start my suspension drop while I have a spare car to drive. Got the rear end done
Before
After
hampton123
sorry for the crappy cell pics still can't find the cord for my camera
hampton123
ok So is there a secret to removing the front shocks? I have never really messed with a coil spring front end before and I can't quite figure it out. When i try to unscrew the nuts at the top so I can slide it out the bottom, the shaft just turns. Is there a squared of piece that I can stick a wrench on or do I just grab the shaft with a pair of vice grips? And i am reusing the shocks till I get around to buyin drop shocks (still not really sure what my options are for them yet).
john
Hi hampton123,
Front shock removal:
I like to remove the front tires for better access. You do need the raise the front end high enough for the shocks to drop out the bottom. You can use vise grips or a 6 mm wrench on the very top of the shock shaft and then back off the nut. If the nut is rusted on, just cut the shaft under the nuts with a sawsall or other cutting tool. Then unbolt the shocks from the lower a-arm.
John
hampton123
Got the front all back together
before
after
