Having Trouble With Ignition Switch
d.-.r.-.e.-.w@hotmail.com's avatar
90-b22dawg [andrew]'s avatar
90-b22dawg [andrew]
trying to get it off the column any pointers? i already have the steering wheel off and the whipper/blinker switch
hex0rz
Ignition switch or combination switch?
IF its the ignition switch no biggie. There is a single screw that holds it in on the back and it will pull out of the lock cylinder. Then, disconnect battery and cut the wires on the back of it as close as possible to the switch.
If its the COMBO switch which is the assembly for the blinkers, wipers, etc. Then yes, the steering wheel needs to be pulled. THEN, disconnect any wiring to the switch, and loosen the screw behind it that holds it to the column.
It'll be just like a hose clamp... After, the clamp part should be loose and the 2 plastic tabs should be loose. Just shimmy the assembly left and right and break it free if its a little seized up. After, it should just pull right off with no hassle!
When reconnecting it, make sure that the ring in the front that has 2 points on it aligns with the holes in the wheel or you could break it! I went a long time manually turning my turn signal on and off! LOL!
90-b22dawg [andrew]
i am trying to get off the part that the key goes into.... and the aluminum part that goes around the column.... the entire assembly.... i already have the blinker and whipper assembly off the column....
V
v8mazda4ever
there are 2 flat screws on top just use a grinder and slot them and then a large flat head screw driver and it willl come off bro.
90-b22dawg [andrew]
thanks
90-b22dawg [andrew]
got it off but had to drill out the head of one screw because i don't have any good bits for my grinder
yup just reinstall new screws
