drive shaft Q?
subliminalmatt@hotmail.com's avatar
drive shaft Q?
scootch's avatar
scootch
i have a 86 single cab long bed i just got from my dad. it was his daily for a while but its been on a downward spiral for a while. there is this horrible clunking noise when taking off. was told the drive shaft was f**ked. anyone ever mess with these? i was thinkin it was the u joints but someone told me it could be the carrier bearing is plum wore out. any help would be great.
also how hard is it to remove these staked in u joints??
snoplow
if tis the hangar bearing you will have to unbolt it from cross member and get it changed out. i took mine to a shop to get it done. the new hangar bearing is about 25? fom oreillys
immortal1 (linn)'s avatar
immortal1 (linn)
U Joints on these trucks are not to difficult to do your self at home. The carrier bearing can be done at home with a gear puller and some creativity. Your best bet would be to prop up the truck on jack stands, crawl under there and see if the u-joints have any noticeable play in them. The carrier bearing usually squeals when it goes out where as the u-joints make more of a clunking noise.
maztang (ryan)'s avatar
maztang (ryan)
what up scootch! finally got a truck, nice! you need to bag that bad boy!
