5 Lug Conversion?
5 Lug Conversion?
W
will
How can i do this, i read about yota rear ends... and such. Because im droping my b2200 project untill i finish with the motor. Buying a b2600i and i want to fit my old koings on it.
oldspice213's avatar
oldspice213
i cant help you out but if you look around the forums long enough there is alot on this topic
nc4life's avatar
nc4life
Here is the post about it. The guy you want to talk to is LaynRockers(John).
All you do is have him drill your front hubs and BAM you can fit your 5 lug wheels. And in the rear just run yourself a toyota rear.
W
will
What yota rear end does posi? and what brake setup should i use? because obviously ill need new rotors slotted and drilled preferably.
nc4life's avatar
nc4life
Don't know about posi toyota rearends but here are the years and lengths
73-78 ~ 53" pre-Hilux and stouts
79-83 ~ 55" Hilux / 1st gen pickups
84-88 ~ 57" 2nd gen
89-95 ~ 58.5" 3rd gen
95-04 ~ 60" Tacoma
You could probably talk to him about maybe slotting some stock mazda rotors for you. Not really sure he probably could tell you about that.
phatmike
will the ranger hubs not fit on a mazda?
oldspice213
how wide are the mazda axle in the rear
nc4life's avatar
nc4life
oldspice213
so if i as to get a yota rear which one do you guys suggest
hdyfz450
what is the gear ratio on a 87 B2000 rear axle compared to a toyota axle... Im thinking about going the toyota axle and wanting to lower my ratio to get better highway miles. Any info on gear ratios?
