18 inch wheels
platinum87_@excite.com's avatar
18 inch wheels
trucks&stuff's avatar
trucks&stuff
i am gonna run 18x8s on the front of my truck with a five lug conversion using toyota spindles. how much backspacing do i need? i have searched the site and couldnt find anything, any help would be greatly appreciated!
nc4life's avatar
nc4life
I can tell you that I have a 20x8.5 wheel with 6.32 in backspacing, thats with 4x4 sheet metal. If you have 2wd sheet metal they will not fit, with out some type of modification to the suspension. I know most people when doing the toyota conversion run with a 7 or 7.5 wide wheel. So if you run an 8 inch wide wheel you probably will need a aleast 6 or 6.5 wide wheel. Hope that helps, maybe someone will jump in that has a 8 inch wide wheel. Also how low do you plan on going and are you bodydropped?
trucks&stuff
i am gonna body drop it to the pinch, and i will be runnin 2wd sheet metal.
sonikk71's avatar
sonikk71
I am not sure what change the yota conversion will have with regards to widening or narrowing your suspension, (from my memory nothing) but I can tell you from experience that if you are gonna BD to the pinch with 2 wheel drive sheet metal (my truck has that although I got rid of the pinch) you with an 8 wide rim you need a +45 to +51 offset if you want it tuck cleanly. Dont forget if you run dropped spindles that will change. What are you going to do in the back?
trucks&stuff
so if i get 6 inches of backspacing i should be alright.
i am gonna run a narrowed tacoma rear with 20x10s; it should have a killer stance.
thanks
nc4life's avatar
nc4life
Nothing on the front, but when you do the rear its narrower.
