Mazda Fuel Pump
Mazda Fuel Pump
dragn37
I have a 1992 Mazda B2200 se-5.. Is the fuel pump in the gas tank? or is it under the hood or inline somewhere? im about to buy a fuel cell, and didnt no if i needed a fuel pump. Thanks a lot..
jeff
bodied b2600zx (josh)
you always need a fuel pump when installing a cell.... You jus need to get one that can pump the pressure required by your truck..... IF I'M NOT MISTAKEN
LD
low down89
i think if your truck has a mechanical fuel pump you can use the faactory pump but i could be wrong
dragn37
ok, so0o..i need to get a external fuel pump because mine is in the gas tank right?????
midnightmike's avatar
midnightmike
yup
layinfrm18s
Man i just put a Cell on mine and its running of the pump that is on the motor. that is all i did
LD
low down89
thats how i am planning on doing mine as soon as i get the time to do the work and i don't fill the factory tank up on thursday i always fill up on pay day gotta not do that one week so it will be easier to remove the factory tank
ya i guess if you have a mechanical pump on the motor, you can just put the cell on and run the lines... If your pump is IN the tank then you'd have to get an external pump
dragn37
Ok, so let me get this straight;
If i have a fuel pump in my stock gas tank, ill need a new external one.
If thier is not a fuel pump in the gas tank, and its off the one under the hood, then i DONT need a external one..
Wait what???? im mad confusedd
LD
low down89
ok look on the passenger side of your head at the rear and see if you have a pump there if so you can just jook up the lines and roll if not you will have to buy a new pump and a pressure regulator
