Cadillac wheels?
X
Cadillac wheels?
joemazda93
Well, I just bought a pair of chrome eskie's In mint condition for a $100. My question is that can I run 225's on them, and also if I can will they tuck? My truck is bagged and the inside lip of the bed is cut for extra clearance. I found a guy that wants to get rid of 6 225-45-17's for 60 bucks.
90-b22dawg [andrew]'s avatar
90-b22dawg [andrew]
yes they will tuck and yes you can run those tires as long as your front inner fender wells are cut out.... unless you only want a drop like my sig pic which is the tire touching the inner fender well...im runnin 215/45/17s
joemazda93
Thanks alot man, Yes my front ineer wheel wells are gone. I just can't pass a deal like this up the tires are about 75% life left.
crazymikey's avatar
crazymikey
sounds like you're all set then.
those tires will be a good size and give you a good ride.
I had 205/50/17s and 205/40/17s on mine and the 40s handled way better and the truck sat nice,but the 50s gave a better ride at the expense of handling and ride height.
You're at a good compromise with the 225/45s.
Just watch out if you have drop spindles on your truck,due to the offset of the rims,they will be pushed out further and you may rub. I had major rubbing issues with my eskies and drop spindles,so I had to run a lower profile tire and even add 4x4 fenders with a cut out inside lip for extra clearance.
crazymikey's avatar
crazymikey
oh,also be aware you need the centres of the rims bored to about 3 3/8" if I remember correctly,as to clear the Mazda hubs,or simply grind off the tabs on your hubs and get some hubcentric lugs.
