what stock rims from what make and model trucks and suv will fit the 89 mazda b2200? just want to see what my options are thanks in advance.
elbine69
Anything with a 6x5.5 bolt pattern. Chevy, GMC, Nissan, Toyota trucks and suv's, Escalades. Lots of options.
crazymikey
Gotta watch with a lot of those rims,you have to either bore out the centre or grind the tabs off your hubs.
90-b22dawg [andrew]
probably easier and cheaper to just grind the tabs
z71's
crazymikey
you want to watch the offset more than anything. some rims will stick out further than others and make it harder,or impossible to tuck if you want to go that low.
3 Common choices are:
Nissan Pathfinder
Chevy Z71
Cadillac Escalade
g_money
another quick question if i was to go with some centerline smoothies how big could i go with out rubbing i just want to throw them on as soon as im done with the engine rebuild and paint shop. i have 2wd fenders
90-b22dawg [andrew]
depends on what size tire you run and how low the truck sits
g_money
its still at stock height but i want to drop it a inch or 2 nothing major if i was to go with 17 or 18 what tire you think i should run on them
RX
racer x
Depends on the rims width.Lots of guys run a 225/35/18.But thats as small as you can go on a 8" wheel.
