grinding tabs
13 following
effdbmx1@gmail.com's avatar
grinding tabs
effdbmx1's avatar
effdbmx1
so i got my wheels mounted onto my 17's today. they're off a chevy so i need to grind my tabs. can i completely grind them off or is it better to just grind them down untill they fit into the chevy center hole?
outkastdawg's avatar
outkastdawg
that or you can just have them bored out to fit
effdbmx1's avatar
effdbmx1
it will cost money to have the wheels bored. and i can grind the tabs myself. my question is, do i completly grind them off, or do i just grind them down until the wheel can fit on it?
jmzcustomz (jeff)'s avatar
jmzcustomz (jeff)
On my old one I just ground them flush and mounted the wheels. Rocked them for about a year that way. I would recomend a lug nut up date. OH yeah if you are using a huge grinder....dont drop it on your leg. It will damn near cut it off. Still got a huge scar.
elbine69's avatar
elbine69
If you have a router you can bore the wheels out yourself. Theres a couple how to videos on youtube.
effdbmx1's avatar
effdbmx1
did anything happen after a year? or did you just change something? i'm not sure i'll even have my truck for another year but you never know...
dropndragmazda's avatar
dropndragmazda
dude my my tabs have been grinded down to where the wheel fits! I have'nt had any problems, might need to buy different lugnuts though!
Post was last edited on Feb 19, 2008 07:19. Edited 1 time.
devb22's avatar
devb22
Blah Blah Blah
Grind them down flush, and then use a conical/self-centering lug nut...an open style would be best so you don't bottom out on the stud!
You'll be fine as long as you get the self-centering lug nuts!
Dev
dropped90(justin)'s avatar
dropped90(justin)
mine have been grinded for awhile with no problems but you need to upgrade lugnuts to the bulge seat nuts. others are about to small and arent to safe.
on and mine are grinded flush and you dont need longer studs
-justin
watt's avatar
watt
i would grind them just to clear so the wheel sits right instead of going all the way flush...its easier to grind more if needed as to wishing you didnt do too much.....my opinion but i would get the wheels bored....and do it yourself if money is the issue?
