Wheel Question
pocket_rocket05@hotmail.com's avatar
Wheel Question
devb22's avatar
devb22
Lets say I have a 5 lug swap, re-drilled hubs in the front and a 89-95 yota axle in the rear.
Would you think that a set of 20" X 8.5" with an offset of +35mm wheels would tuck on 4wd sheet metal?
Thanks...
Dev
dropped90(justin)'s avatar
dropped90(justin)
from what understand you need atleast +35mm with 8" wheel so it sounds like its gonna be a no. someone with more wheel experience could better help you though
-justin
devb22's avatar
devb22
Hmmm....
Dev
V
v8mazda4ever
I know more about the offsets in inches and the eskies I have have a 6 1/4 backspacing and when machined out they will tuck really nice. so what would + 35mm offset be in inches.
devb22's avatar
devb22
Well...
25.4mm = 1inch
Offset = (35mm)/(25.4mm/in) = 1.378 in
1/2 Wheel Width = (.5)*(8.5 in) = 4.25 in
BS = (4.25 in) + (1.378 in) = 5.628 inches
5.628 Inches would be the backspacing
Dev
V
v8mazda4ever
It would be close would have to make sure the rubber you are putting on the rims don't ballon at all and you would have to roll the fender lip.
devb22's avatar
devb22
Hmmm....
Dev
devb22's avatar
devb22
Even with the shorter Yota Axle do you think I would have this problem?
Dev
dropped90(justin)
even if it tucks behind the fender lip. dont forget about once its layed out. if it barely clears the lip its gonna chew some tires up when layed out.
-justin
devb22's avatar
devb22
Yaya...
Dev
