how to wire Danz valves?
avyon22s
i bought new Danz valves, the plug is made to hold 3 wires but they sent 2 wire cable with no diagram. Can someone tell what goes to what?
Blitz Noma's avatar
Blitz Noma
use the left and right prongs. doesnt matter which you power as long as you keep them the same with all the valves...
916mini's avatar
916mini
There should be 2 prongs that are vertical and one thats horizontal. Don't use the horizontal prong. On the vertical prongs you can put them either way, I usually go left ground right positive to the switch box.
Victor@FBIrides
avyon22s
alright thanks guys hoping to get it wired tomorrow then
BankruptRam's avatar
BankruptRam
I'm glad to see this! I was about to throw mine away cuz I couldnt get them to work or find a diagram.
bagdb2200
Word. Wire it like they say. It doesn't matter which is positive and which is negative, you're just energizing a coil. The horizontal prong is for if you want to ground the solenoid to itself. You'd run a wire from one vertical prong to the horizontal prong. Then power from the switchbox to the last one.
s10
last post by baha +1y
