you can obviously stock floor anything... im not an idiot. i guess i should have chosen my words more carefully.. can you lay rocker on a 02 silverado by just lowering the body mounts
bdroppeddak
you cant stockfloor a window crank from a 1985 volkswagen cabroliet.....
podslammed
If you look back and find the issue of streettrucks with the ekstensive hummer they have a tech section doing an 04.
one_low_sixty8
awesome, thanks
MF
Master Fabber
Actually cris I have done two of those-came out rather sick.
one_low_sixty8
actually you can...you have to change it from a 36 spline and grind down 4 degrees on the north end to a 29 spline and clock it at 17 degrees counter clockwise. it should work. however an 86 cabriolet is a whole different story due to the set screw...
