Double Crew.....
Double Crew.....
lowbudgethauler
So I have been brainstorming lately and came up with this idea, stretching my Crewcab to a double crew, I have found a place in michigan
I inquired as to how much this would cost, with no paint work and the interior left unfinished.........
you may want to sit down.....
$18,000!!!!!!!!!!!!!!!!!!!!!!!
I think not, so I am in the process of procuring a 98 crew cab with the frame cut at the front and rear of it, benefits are 2 fold, upgrade to a later style interior, and have everything(almost) for the double crew conversion 2 begin.
Has anyone experience with this on the boards?
Les if you are out there respond
1low1ton
mine was an extended cab when i bough it i stretched the frame and put the crew cab on it i could do the work for ya
liljlowrider's avatar
liljlowrider
that would be sweet but hard as hell to drive.
krewzlo's avatar
krewzlo
I saw one quite a few years ago in Pigeon forge, stock height but didn't look proportionate to the front end and the bed looked super short compared to the cab, I have always wanted a ford f350 ext, crew cab. They made a few of them back in the mid 90's I believe it was. they look pretty good but I think only in 4x4.
1low1ton
i started to put my extended cab section behind my crew cab but it did look really out of proportion maybe if you lengthened the bed about 2 more feet and added a second rear axle and had it on 10 semis it would be pretty sweet
rhmdually
haha just imagine parking a truck that long lol
guilty by design's avatar
guilty by design
i made my 2dr yota into a quadcab and it wasnt bad. The main problem youll have is making a c pillar if you dont have 2 crewcabs to work with. It would def be cool, all ive seen are stock or lifted trucks.
1low1ton
i seen a lifted one i branson mo about 5 years ago and that bitch was huge
W
watahyahknow
take a suburbbody cut it short after the reardoors take a rearwall from a pickup and stick that on a lengtened frame with a bed behind it .
think it would be a lot less work and the doors wil be eazier to fix in case of damage
if you get a complete donorvehicle you have the interiour bits too you only need to cut the carpet and the verry rear trimming
lowbudgethauler
I already have a 2nd crewcab lined up
