chopedmazda
will an arc welder work for trame work and sheet metal.... i know it will spatter alot
impulse's avatar
impulse
wow.
drptndrgn's avatar
drptndrgn
wont work... but good question...
chopedmazda
y wont it work...not enough penetration
dragyours2001's avatar
dragyours2001
To much heat
scottshonda
Will work ok for frame work. But yes to much heat for thin sheet metal.
bodydropped85's avatar
bodydropped85
umm
91 drggn dime's avatar
91 drggn dime
I know a guy here that still believes in only his arc welder and nothing else will penetrate enough for strength.. it works for frame, but not for sheet.
bdroppeddak's avatar
bdroppeddak
an arc welder can do both, problem is most people who actually can run an arc welder wouldnt use it for this application.
NRChopShop's avatar
NRChopShop
Edited: 10/9/2006 7:05:14 AM by NRChopShop
hahaha what do you guys think they used before migs and shit became easy to access? Not everything was gas welded...that takes to much time. sheetmetal can be welded with and arc welder with the right rods and heat settings. The main problem today is that modern sheetmeatl is way too thin to mess with and arc welder
hell the shop manual for my 51 actually has pictures and a step by step quarter panel patch part that shows it being arc welded
