relays
15 following
jaslaven@cox.net's avatar
relays
lilslay's avatar
lilslay
why do i need to use relays on my door popper soleniods and my compressors? i dont know tha purpose
low99maz's avatar
low99maz
Cause thats the way grandma made them
TwistedPhil's avatar
TwistedPhil
Basically, a relay is a heavy duty switch. The circuitry inside your door popper kit's brain, and the guts inside a pressure switch, aren't designed to carry a heavy electrical load- they just carry a signal. A relay takes that signal and uses it to trigger an electromagnet, which moves a physical switch inside the relay to provide your solenoid or compressor with full battery power.
Your pressure switch will last longer, and your pump will run stronger because it's getting cleaner power! YAY! Let's hear three cheers for RELAYS!!
-Phil at FBI
Dragthatchit's avatar
Dragthatchit
WORD!!! That is the Truth..Well put PHIL!!
lilslay's avatar
lilslay
o......ok lmao thanks, where could i mount the relays....anywhere?
Low_SST's avatar
Low_SST
are you guys really rocking relays on your wire from the brain of your door solenoid to your solenoid?
chevygurly's avatar
chevygurly
Originally posted by framelayer521
Basically, a relay is a heavy duty switch. The circuitry inside your door popper kit's brain, and the guts inside a pressure switch, aren't designed to carry a heavy electrical load- they just carry a signal. A relay takes that signal and uses it to trigger an electromagnet, which moves a physical switch inside the relay to provide your solenoid or compressor with full battery power.Your pressure switch will last longer, and your pump will run stronger because it's getting cleaner power! YAY! Let's hear three cheers for RELAYS!!
-Phil at FBI
SO YOUR THE SMART ONE AT FBI JK
COULDNT HAVE SAID IT ANY BETTER
91 drggn dime's avatar
91 drggn dime
mine are built in, but my brain does have them.. i installed a Protocol kit awhile back and it had to have external relay's and yes, i use them whenever i can. hell i have my bags wired up to my remote
Low_SST's avatar
Low_SST
i have the spal 35lb kit and i think its fine, my poppers slam open, i was also wondering what people use instead of the wire, i know some have used a wire hanger type of thing but is there something better that has no play like the cable does.
91 drggn dime
I have the same kit you have and the relays are built in.. mine is a 7 channel.
the cable will have a little bit of play, its what the directions say.. as long as the latch fully opens when the noid is all the way down youre good.. mine has very very little slack.. you just gotta take your time on it and get the cabvles right and then clamp em.
