taco rocker
30 following
taco rocker
aesthetikustoms
i never see any tacomas that are completely laid out to the rocker, theyre always to the pinch. does no one want to cut that bed corner down? anyone have pics of one and im not talkin doored just rockered
CommonVan
its not just the bed. the motor goes out of the hood and u have to cut the trans tun out.
badcoma's avatar
badcoma
i'm to rocker and so is Gfreezo on here. and once my new frame is done my motor will be under my hood. not sure about the trans though hoping for it to be under the floor. didn't cut it the first time and cleared.
CommonVan
i stand corrected. i have new frame frome control arm back and the motor rubs botom of hood with pinch
TacoFel's avatar
TacoFel
Edited: 6/6/2006 7:47:31 AM by TacoFel
Shit, I'm on the rocker HARD! F that pinch crap, Reworking the bed corner was cake! The thing that gets me is the guys that are BD with no Z and the front never lays at all. Here is a pic opf mine sittign hard.http://www.dropndrag.com/images/shows/2005/features/eriktaco/e5.jpg
keele's avatar
keele
The front wheel is like off the ground for the most part. That is some sick camber.
TacoFel's avatar
TacoFel
Teh pic is decieving, but a tiny bit of it is off the ground.
chumpchange's avatar
chumpchange
i am body dropped with no Z and lay flat rocker all the way around. i reworked the front crossmember and the rack and pinion and it lays flat with the stock hood and no hump in it. its hard to tell from the pic but it lays hard.
aesthetikustoms
tacodragnazz, without z-ing the frame you didn't have to lower the motor. also with the modified x-member how much did you raise it and was the oil pan an issue. looks sick by the way.
chumpchange
i did a 3 and a quarter traditional body drop. i didnt have to lower the motor i just notched out some of the webing under the hood and had to section a quarter inch out of the power sterring reservoir for hood clearance. raise the clutch master cylinder and as for the cross member i cut the bottom off of it were it is welded together and sunk the botttom that i cut off up inside of the crossmember until the truck layed out flat and then welded it back up. the oil pan is barely off of the ground and the rack and pinion you wil have to grind on the bolt heads and the mounts to get it to lay out but it is very minor grinding. hope this helps you.
