check valve between valves, good or bad?
F
F
fourto50
sould a check valve be between your valves or some place esle, i bought 1/2 smc,s off ebay, guy had them on his car, so i geuss he put them there like that be is it good or bad, cause they dont seem fast to me?
laidout94toy's avatar
laidout94toy
I see alot of check valves all over air systems now. Like after the valves before the bags. Just a (just in case) saftey issue I guess.
mindlissmetalfab's avatar
mindlissmetalfab
after the valves before the bags wouldnt really work i dont think. It would have to be before the fill valve. It would prevent the bags from leaking down if the tanks ever lost pressure.
eks10BDRG-N's avatar
eks10BDRG-N
never herd of that being done before, only between the compressor and tank that i know of.
mindlissmetalfab
People run them because if you ever lose tank pressure, your fill valves will open up and the air from your bags will drain out through the fill valves. I dont think it happens with ALL valves, but some need backpressure (ie tank pressure) to stay closed.
F
fourto50
when i say beteen, i mean, between the fill valve and the release valve?
bagged89S10's avatar
bagged89S10
I run check valves right before each fill valve on all my setups. I mean you really don't need them but it's good to have just incase you blow a line from the compressor or if your compressor takes a shit. This way if your tank loses air, You don't lose air in your bags.
ahab's avatar
ahab
Wait till you have to drain the system and take the airline out of the airbag. That shit isnt comin out. Not with pressure on the line.
olskoolpup
just drain the tank and hold you dump valves down for longer than you usually would. no biggie
dwnlowx
thats when the flick off the switch helps
s10
last post by baha +1y
