Bagged Ford is lower on 1 side than the other
james@crescentvans.com's avatar
fordford's avatar
fordford
I just noticed yesterday that when I raise my truck it comes up more on 1 side than the other.I need help which way do I go?I can't find any leaks.It has started leaking down over nightJust in the front.
2stock02
Let me guess it comes up more on the passenger side? If everything else is stock with the battery and gas tank on one side the weight makes a difference...and to help find the leak I have heard Windex works well when soap and water not cutting it
jmn444's avatar
jmn444
^^^ ditto, i think it's more important that it sits level aired out than lifted.
rangerlover's avatar
rangerlover
it's a ranger they all do that
grillift
all trucks do this if your not runing 8 valves. theres more weight on the drivers side then pass. thats what i like to call the gangster lean.
bodydropped85's avatar
bodydropped85
if its a ibeamer one beam is shorter than the other.
minitruckpunk
Weight. Bag mount could be lower on one side than the other. 4 valves shift a lot of weight.
s10
last post by baha +1y
