B2600i turn signals f'd up
tomkat
I have a '93 B2600i and the drivers side front turn signal has never worked since I bought the truck. The wiring looks ok at a glance, but the running light doesn't even come on... and today, the passenger side front turn signal stopped working too... but the running light still works. The drivers side has always hyper blinked since only the back works. The passenger side started doin the same thing today when it stopped working. What's goin on?
dssur's avatar
dssur
First things first, make sure the wiring for the bulbs is connected, they have quick disconnects right behind the bumper.
If thats ok, take the bulb out and look at the terminals in the socket. Water gets in and boogers up the works pretty good. If yours is corroded and you cant clean it up (most times a little scootch of sandpaper will bring it back), I have a couple extra, send me your address and I'll send one to you.
The other side that just quit, could be corrosion, but more likely that filament of the bulb is out. THere are two filaments in those bulbs, so its possible to have the turn work and the running light be out, or in your case vice versa.
mr.safety's avatar
mr.safety
you shuld just ask me to come over and check it out tom
tomkat
Thanks Russ.
Hey Shane, umm, my turn signals broke... can you come over and check it out? That would be grreat mmmkay?
