rebuilding engine
rebuilding engine
lownism0
Is there anything I should look out for when doing this? I found a complete engine rebuild kit off of ebay that comes with everything I need.
mjavy7's avatar
mjavy7
righty tighty lefty loosy. If you have bolts left over say "oops" and keep going. j/k
Well if you have done it before is no big deal. If you have not you are in for a long week. With that said, if it's a b-series engine.... this is one of the simplest engines to learn with.
lownism0
sorry I guess I should have posted that its the 2.2 with a carb.
tomkat
You need valve stem seals, intake gasket, exhaust gasket, head gasket, valve cover gasket, fuel pump gasket, carb gaskets (if you can afford it, put a Redline RGM or a Weber on there) rings, rod bearings, main bearings, maybe a new cam (Delta Cam in Tacoma WA makes performance cams as well as a few other places)
I've never rebuilt a 4 cylinder or any car/truck motor for that matter, but Mazdas are pretty easy to work on (unless it's a Mitsubishi-powered B2600 minus the i; those are a bitch) Just get a friend who's rebuilt stuff before to help you out, and if you have all the tools/equipment you'll need, and don't get sidetracked too often, you could get it done over a weekend once you have the block back from the machine shop.
