headlight help...they wont come on!
Q
bagman
when i turn the switch on...nothing...leave it on for a while,eventually the park lights come on???ohh...and i got 2 new headlights in it...is it the switch or is there a relay somewhere...its a 90 se5 standard cab wit power steering and ac.
dssur's avatar
dssur
If its both the parks and the headlights I'd suspect the switch.
You can take apart the column plastic and meter the switch if you are electronically inclined at all. If not, you are going to end up throwing parts at the problem. The switches do go bad though.
juiced150
check the fuses?
bagman
Originally posted by juiced150
check the fuses? fuses in the dash are fine and under the hood as well...im gonna try what russ d said
bagman
Originally posted by Russ-D
If its both the parks and the headlights I'd suspect the switch. You can take apart the column plastic and meter the switch if you are electronically inclined at all. If not, you are going to end up throwing parts at the problem. The switches do go bad though. u talkin about just a test light or like an amp meter...no accsess to meter.but im pretty sure its got to be the switch cause u can twist it a certain way and the parks come on and i can pull it back and the high beams will come on untill i let it go
bdroppeddak's avatar
bdroppeddak
hell if you got bags air the rear up and tape the highbeam switch on
dssur's avatar
dssur
sounds like the switch to me.
bagman
yeah,chris that'll work!!!lol!!
bdroppeddak
lol i had the same troubles with my truck, never could figure it out, i even swapped the steerin column...... but my hibeams didnt even work.
wht01ranger's avatar
wht01ranger
kept telling you to get more headlight fluid
