hey guys i was moving my truck to the other side of my shop this morning and when we started the clutch was hard as a rock it will go in gear but will not move or stall out. is this my slave cylinder or my master clyinder? thanks lata josh
g&k_customz
COME ON SOME ONE KNOWS?
mazdalowandslow
So is it engauged or disenguaged?
brandon005
ummm...its either the master or slave but i'm not sure ask here www.mazdatruckin.com you will get an acurate response
wht01ranger
you can't press in the clutch pedal?
if that is the case, check your linkage, then the master cylinder...i've never seen a master cylinder lock up though
g&k_customz
Edited: 10/22/2005 8:51:00 PM by VCNCBAGGEDMAZDA
its weird at first in went stuck to the floor so i pumped it with my foot thinking it was the slave cylinder but now its hard as a rock like a brake pedal.what gives?
g&k_customz
ITS DISENGEAGED SO DOES THIS MEAN ITS THE PRESSURE PLATE?
bdroppeddak
so even if you arent pushing the pedal, the clutch acts like its disengaged?
g&k_customz
YES IT ACTS LIKE ITS DISENGAGED EVEN WITH OUT PUSHING THE CLUTCH IN IT WILL START RIGHT UP IN ALL GEARS
bdroppeddak
is the slave cylinder extended? like its pushing the fork?
