motor swap, no start
marty313
ok, i swapped my old b2200 motor with a b2000 motor with 2.2 heads and a pacesetter header. i finised the swap, hooked up everything as it was.. but now it wont start. it will crank but wont start. all my plugs and all are right.. i cant set the timing till i get it running.
dssur's avatar
dssur
Check for gas, check for spark. If you have those two, here is the old adage: "its always the ignition" Check static timing, make sure the distrubutor isnt a tooth off.
