Shaving door handles opinion.
luvherbooty@gmail.com's avatar
jcordova's avatar
jcordova
I have shaved many of them. I have always made a template to weld in. I know that some people cut out the handle impression and weld in a square piece of metal. What is your opinion on this?
BankruptRam's avatar
BankruptRam
Never cut out the handle, just remove it and filler piece it! It will almost always warp if you cut it out. Just make a filler peice and weld it in.
jcordova's avatar
jcordova
I always thought it would warp more if you cut it out, but I here people cutting them out?
TacoFel's avatar
TacoFel
The stock flange will help retain the body, without it it will definatly warp more.
sweeden's avatar
sweeden
if u cut it out and weld it in its better i think but much easier to just weld in filler
Stock Sucks's avatar
Stock Sucks
Leave the factory stamping...this gives that part of the panel rigidity like any type of bodyline would...if you cut it out the panel has less strength and will warp. Think of a pizza pan, if it is just flat you can twist it, but with that little rim its solid..
PHATWAGON
i know of poeple in AZ back in the day dont even use a filler they used duck tape and then bondoed over it - how sad is that
GDAZ
We saw a truckin the parking lot at Truckin Nats that had a plate screwed with sheet metal screws, guess he got discouraged cuz his other door was warped like I have never seen before
