20's on rear of mazda
16 following
U
urdaddy
whats up people im wanting to put 20'a on the back of my dawg...just wandeing how much i need to shorten the rear end and if i need to tub the fram in any ?....and if any one has any pix of mazdas with 20' bring um...thanks later
jeebus @ mmw's avatar
jeebus @ mmw
you didnt really state if you were bd or just bagged or even stock.
but regardless, you shouldnt need to narrow the rear end at all, or tub the frame. Just have the correct wheel made with the right width and back spacing. I have a pic in my profile of when my truck was green primer, i had 20's on it all around.... the newer pics are 18". but this next year, i am going with 20's all around on it again...just gonna get them made with the exact BS i need and wheel with.
taylor
N
NCBIGGJ
do a search, mine is on 20's , there is a couple others on here as well. The search key is going to be your best bet.
truckguy2000
if you wanting to run chrome you need a courier rearend and a sub frame really to run any 20 you need a shorten rearend for it to be rear world pratical i don't want my wheel sparking or smoking off the notch/frame
jeebus @ mmw
hmmm, the old 20" chrome wheels in had on mine didnt need and narrowing or anything. Just bolted on. tucked fine, and drove fine.
idk, its all gonna depend on the BS you get.
taylor
bdroppeddak's avatar
bdroppeddak
if you can get an 8" or less wide wheel you could do it with the stock frame, but you'd pretty much need a suuuuper high offset, or an older yota rear end to get a FWD offset 5 lug 20.
bdroppeddak
taylor there is no way those 20s you had woulda worked bodydropped, they barely fit inside the 4wd flares.
jeebus @ mmw
well, i didnt see anyone above mention a bodydrop. did you?
and mine were 20x8.5 with just under 6" of backspace.
N
NCBIGGJ
Mine are chrome rozzis. Didnt narrow the axle at all.
boooghar's avatar
boooghar
i have 2 courier rear ends in my junk yard
