s-10 window crank question? help me out
BLACKMAGICON24S
hey guys, i have a 98 s-10 im trying to take off the window cranks, do i just pull them off or do they have a type of pin that has to be pushed in?
cruisinlowS10
on my first gen s10, there is a keeper on the cranks. if you have needle nose pliers with the ends that fork upward those are what i would use.
BLACKMAGICON24S
So do i have to take off the door panel or just put 2-screw flat screw drivers behind the window crank and pry the crank off?
deflaytedwayz2
no special tool needed except a shop rag. find where the open par of the clip is and put teh rag in on theat end and pull up in a back and forth motion and they pop out every time
BLACKMAGICON24S
thanks bro, i was hoping the rag trick wild work, ill go try that right now.
BLACKMAGICON24S
WELL I FOUND THAT THERE IS A PIN THAT REQUIRES A TOOL WITH A CROOKED SPIKE THAT IS NEEDED TO TAKE OFF THESE STUPID ASS WINDOW CRANKS.
F
finaldime
use a wet bath cloth and go back and forth behind the crank it will remove the horseshoe type clip
bodydropped85's avatar
bodydropped85
there is a tool for this it has a |_| shape to get the clip out.
DougyFrisch's avatar
DougyFrisch
there is a special tool that makes it easier, but it is not required. just get behind there with a flat head and pop the bitch off.
deathtorice
Just buy the window crank puller. It is only like a dollar, and makes it much easier. Oh, when you go to put it back on, you can just put the c clip in the window crank handle, and it will snap right back on the crank stud thing. I learned that after trying to put the crank handle on, and get the c clip in afterward.
