BD mazda to Rockers
custommazdaspeed@gmail.com's avatar
BD mazda to Rockers
mazdalowandslow's avatar
mazdalowandslow
Alright heres the deal... i need to know how many inchs to raise the floor of the cab to let it lay rocker.... im cutting off the pinch and rewelding it... by the way the cab is off the frame... Thanks for your feedback!
Gmoney2
give it a 4 inch and section the rockers if your going to reweld the pinch anyway then you will lay on 1/4 inch rockers, thats what mine is.
dssur's avatar
dssur
2 inches will lay pinch weld, 2.5 will lay rocker. This assumes you drag your front crossmember down a bit. What the hell its over built anyway.
4 inches would work, but 2.5 would do it.
N
NCBIGGJ
what Russ said..
truckguy2000
yeah 2.5 will even give you some roacker to drag off if i'm not mistake it will lay rocker hard
N
NCBIGGJ
Mine is 3", I cut off about a inch of mine rocker.
