Bagged Mazda Not Layin!!
16 following
CM
c mau
alright this is not my truck its my freinds jsut got doen bagging it and shit got the rear brackets at the top of the notches all that happy horse shit but layewd out the shit doesnt lay frame!!! u cant put ur fingers under the frame its that damn close..he has no drop spindles or enthing..could that it beit ?? why doesnt this dawg lay the fuck down!!/.
Thank you,We Need To Drag!!
bdroppeddak's avatar
bdroppeddak
hm.. must be an installer problem, my truck lays fine.
mazdawg71
did u flip the ball joints?if so and it still doesnt lay sometimes you gotta put a spacer between the lower control arm and the ball joint to give it that extra drop!Sinfull Creations Ontario;s lowest!!!
CM
c mau
ok thanks for the help and nto braggin...neways back to my question neone goit ne ideas and its runnin a 4 link too...if that matters..
CM
c mau
and htank you mazdawg71 ill try that
bdroppeddak
lol give us more info like tire/wheel size
mazdawg71
ir it doesnt lay in da back then yes its an installer problem!!!!good luck!
CM
c mau
escalades with i beleive 40 serioes wheels..its so damn close that i can smell it !! haha but im not sure if the balljoints are flipped yet or not i gotta talk to the guy who did it//cuz i wasnt there for the front install...and should the back lay regardless if the fronts down or not?
bdroppeddak
cut the spring perches off if they arent, make sure the inner fenders are cut out of the front and rear, in the front flip the balljoints to the top of the arm, trim the part of the lower arm that hits the frame, and boom if the bags are set right, the truck will lay frame in the rear , and xmemer in the front.
dssur's avatar
dssur
front: look at the crossmember between the lower control arms, is it on the ground?
rear: your rear leaf perches, did you trim them a little? they hang slightly lower than the frame too.
