Miller 135, Spool Gun?
whynotfab avatar
whynotfab
Anyone here personally have/use a spoolgun for aluminum welding on their Miller 135? My 135 has the small plug on the front for one.. so I was wondering what else is involved.. can I plug the gun right in, or do I need some control module box thing? Gas, wire types? Thanks alot.
Pneufab avatar
Pneufab
Ive answered this before, but you believed the salesman at Airgas over me saying that it is a "direct plug" into the machine
check out the Miller web page
www.millerwelds.com
or your owners manual
you need a sg100 control box and a 3035 spoolgun and of course 100% argon
probably cost you about $600.00 to weld aluminum with that thing and only about 1/8" thickness at that
In my opinion not worth the trouble! You would be better off spending that $600 towards a syncrowave 180sd
t
whynotfab avatar
whynotfab
thanks for the help man, sorry for not believing you before.. i had just seriously thought it plugged right in from what i heard. $600 is too much.. all i wanted it for was making a fuel cell, would steel be fine?
Pneufab avatar
Pneufab
no problem
I also sell Miller welders so it kinda bums me out that someone would give you bogus info like that!
Steel would work fine, just make sure you coat the inside with a sealer
Most stock tanks(that aren't poly) are steel
You can probably run stainless ok if you wanted the spend the extra $$ on the SS and a trimix gas.
good luck
t
bodydropped85 avatar
bodydropped85
yea the spool gun plugs right in and it has the small spool of aluminum wire in it the gun.
bdroppeddak avatar
bdroppeddak
good luck
t
not to mention the price of the wire!! ouch!!!
whynotfab avatar
whynotfab
how do i put my stock sending unit, etc onto a steel fuel cell.. also what gauge steel would be best?
bdroppeddak avatar
bdroppeddak
cut like 1" around the sending unit mount, then weld it to the top of your fuel cell, ive seen a couple built from 16 gauge, some say 14 gauge.
whynotfab avatar
whynotfab
whats the formula to make my fuel cell the same gallons as my stock tank, or close as possible?
