17"s....
17"s....
TheShibbster
Does anyone have some either Denali or Escalade chrome 17" rims for sale? I've been looking so hard to get some but can't, anyone out there be able to help out?
dragginmazda86's avatar
dragginmazda86
Ebay buddy,I've bought two sets of Escalades one set last august for about $500 and the second set last month for $280.hope this helps.
marty313
look on ebay, theres 100 sets, i just got a set for 200$ shipped from cali to me on the east coast...
TheShibbster
I have looked on ebay but the shipping is brutal...i found a set for 300cdn but the shipping is just as much...but i still look on there alot though
TheShibbster
What is the stock backspacing and offset on the 6spoke mazda rims, and what do i need as a backspacing and offset for a set of 17 or 18's to clear all around no rubbing or need of metal work with just a static 2" drop in the front and 3"-4" in the back?
b2200gt
Edited: 9/11/2005 1:05:26 PM by B2200GT
Not to sure about the stock Mazda rims, got rid of them 14 years ago.
17 X 7" wide need 40mm offset (5-1/2" backspace) all around...lots of clearance up front unless you are bodydropped.18 X 7.5" need 45mm offset and can tuck under the 2WD Bed sheetmetal with the fender lip removed, with 1/8" to spare. Plenty of room with a triangulated 4 link. If you've got anything with a Panhard bar, better go narrower.Just remember off set is the distance from the center of the rim to the mounting face. Positive tucks, negative will give you the deep dish look. The tire you chhoose will make a big difference too, on what will rub. A narrow tire on a wider rim will be "rounder" at the sidewall and may give more clearance than a wide tire on a narrow rim. At least that's what I've experienced.
TheShibbster
ok umm I'm lookin at AE Wheels would it be better to look at their charts using the offset or BSM(which i'm assuaming is backspacing) to see what could fit my truck, like heres a rim for instance http://www.aewheel.com/wheels_detail.cfm?id=17 would this rim be able to fit? 17x8??
TheShibbster
bump
burntup
I was told I was out of my mind by a local shop for looking for rims with a 47mm offset. does anybody go back back spacing anymore?
