possibley low on blinker fluid...
11 following
begfomurrcy@yahoo.com's avatar
suckafree's avatar
suckafree
lol yeah, haven a front left blinker issue. I can turn on my running lights, everything works. Right turn signal works, left doesnt. Brand new bulbs, brand new sockets. I tried directly grounding the socket and it still dont blink. I swapped the bulbs around, even tried hacking the wiring and got the left one to blink....when the right is supposed to blink lol. WTF is goin on? Possible bad turn signal switch?any and all info is appreciated!
Drag-N-Low
yeah dude check your fluid, sounds like you have a leak somewhere
Drag-N-Low
seriously tho, might be a bad relay also
primerd85
i got a special going on for blinker fluid this week... hit me up i'll get you a good price ... lol
down2earthdawg's avatar
down2earthdawg
Edited: 8/18/2005 2:42:22 AM by down2earthdawg
have you checked your muffler bearings lately :ROTFLMAO: :VTC:I would check your blinker relay and check if any fuses are blown
NRChopShop's avatar
NRChopShop
the problem is actually in the headlight grease. it needs to be flushed and rebooted
can you hear the relay clicking whenyou turn on you left signal? if you cant hear it clicking, replace it first, then go from there
thatsmydawg's avatar
thatsmydawg
nah man weve run into this a few times its either the switch or the flasher but sometimes with the flasdher i dont remember that oneside works or neither works im not sure check ti out flashers are like $1
stlowburban's avatar
stlowburban
Don't know if this helps but that happened on my wifes buick awhile back and it was the daytime driving light module. Had a burned spot that was caused by a bad bulb. Got everything to hot. You didn't say what year you got so I don't know if you have DRL's. JUst a thought.
Blazed2k3
I would check the switch. I have never seen one side work and not the other, and it be a flasher module. Usually a flasher module is fine if either side operates correctly.
BR549
suckafree's avatar
suckafree
turns out the socket had a bad connection on the inside. Just had to replace it....and top the fluid level and it works fine lol.
