lay frame in front
lay frame in front
drjay2022
i was wondering if i need anything for the front to lay fram on an 86 maz b2k. ive heard you may need drop spindles or control arms, but then will 17 escalde rim tuck? thanks jay
bdroppeddak's avatar
bdroppeddak
205/40/17 will lay like a champ with stock arms and spindles.
maddawg's avatar
maddawg
you'll also need to Z-the frame if you want the frame to lay. ....you did say frame right?
Marshkid1's avatar
Marshkid1
z the frame? are you serious? i'm in the process of a b2k bag job and i've got sclades, and i'm just gonna modify my lowers and uppers to lay out and not bind balls.
-mike
maddawg's avatar
maddawg
what i'm getting at is that it will only lay out on the front crossmember not the frame.
then again...you can always "file down" the crossmember until your nuts and bolts that hole it together are ready to fall off.
Marshkid1's avatar
Marshkid1
ahh, makes sense now, didn't realize the front crossmember was that much lower.
sadisticiron's avatar
sadisticiron
Edited: 8/22/2005 11:36:59 PM by sadisticiron
cutting it up to the control arm bushing and replating the bottom of the pirches will lay frame no need to z re palting the sides and make new bolt hole and a cross member
slamdamazda
no need to z the frame just mod the factory control arms and flip the lower b/j to the top of the arm after you cut the bump out.jeez
maddawg's avatar
maddawg
thats a damn good idea right there.thought about doin' that myself.
maddawg's avatar
maddawg
conrad ,i think i'm missing somthing here...please explain to me how that will get the front of the FRAME flat on the ground.
