stock 87 b2000 a/c compressor
laiedmazda87
there self lube right? i got one but it doesnt pump or suck air... the cluch kicks on and off, the pistons move in and out but it doesnt pump or push any air?? what could be wrong with.. im running a york right now the it keeps throwing the belt off and im tired of fugging with the york, could i just go buya new compressor, fill it with oil and use it just like the york? ill just have to check the oil everynow and then right?
Thanks,Matt
laiedmazda87
anyone??
W
wantmolo
you talking bout using the stock style compressor if so you gotta use a oiler like the one u use on ur shop comp ,but iv also herd that doing it this could mess up the comp someone correct me if im wrong
mazdogs.c
I was told by a friend if you put a oiler on a factory a/c compressor that it will stop it up. I used a factory one on my bodydrop and I just put a drop or two of oil in it once a week depending on how much I drove it.
layinframe2200
i ran a ac compressor off a mazda b 2000 on my 2200 and it work fine for two years and never put any oil in it and it would build up to 200 lbs of pressure. i had the stock fitting on the back side of the compressor machined to fit a fitting to run a line back to my tank.
livinlow
Finally some people who actually do not use inline oilers on the sanden comps,All i hear is people telling people about putting oilers on,Their a dry sump compressor just like the york,you put oil in the crankcase and away you go,Mine works flawlessly,I say ditch the bigass york and use you're stock a/c pump or get one that works,you'll love it.Peace!
laiedmazda87
ok i knew they were dry sump compressors... now i just gotta get me one that works... and yeah the yorks big and heavy but damn atthe air it puts out!! i hope the stock a/c pump will do the same thing and what sanden a/c pump do i need? my stock one on my b2000 is a 508 i believe and it has a screw in the top of the case... man im so happy!!! bolt right up and dont gotta make brackets
time1's avatar
time1
does this work for 91 toyota also??
laiedmazda87
the yota compressor arnt self oilers. i had one but you could put a inline oiler on it.
BTW: what oil do i run in my 87 b2000 sanden 508 compressor???
livinlow
PAG oil #410 you can pick it up at any parts store.Peace!
