parts for fuel cell??
Street_Stylez avatar
Street_Stylez
i am going to buy a 15 gal. fuel cell from summit w/ a sending unit for my frontier. What else am i gonna need?? What fuel pump should i go with??
SNEAKY MONSTA avatar
SNEAKY MONSTA
i would think any aftermarket fuel pump would work you are gonna need a regulator to regulate how much fuel you are sending into the motor and the an fittings to go on the tank and regulator
Street_Stylez
i need some help on which fuel pump to get. I am using a 15 gal. cell from summit. Also will i need to do anything else to the fuel system like a return line?? it is for a 98 frontier
bdroppeddak avatar
bdroppeddak
im guessin you are gonna get a GM sending unit?? i dont think the ford or gm units will read close for a nissan.
bodydropped85 avatar
bodydropped85
also make sure u get some A/N fittings which are hella expensive
Street_Stylez
the gm one will work, it will just make my gas gauge read backwards since it is 0-90 ohm and not 90-0 ohm like my stock one.
truck action avatar
truck action
AutoMeter should have a sender for late model Fords! If EFI you will need a return line & vent.
Street_Stylez
yeah it is EFI. This is becoming a pain in the ass, lol.
insaneautoconcepts avatar
insaneautoconcepts
Why wouldnt you just run the stock fuel sender? I have a 15 gal in stock and can put your sender in it. Just a thought.
bdroppeddak avatar
bdroppeddak
ive heard alot of good from www.aluminumfuelcell.com maybe get one made to use your stock intank unit.
