towing a mini
F
towing a mini
FK
FirstCoast Kreation
Will my 98 tahoe 2wd with the (350)motor..pull my 87 bseries with out any troubles??im goin to wv from florida to pick it up..any input is great..this is to all the tow pig guys..lol..thnks
U
ur2highmn
whats the best way to secure your truck to the trailer? do you guys use chains? or those heavy duty winch type straps? and what do you fasten them to?
U
ur2highmn
anyone? do u use chains and straps? what on the truck do you actually secure the straps to?
pearldrop's avatar
pearldrop
I tow with a 99 Suburban (OBS) and always tow in third.
It isn't just the overdrive that will burn up, it is the whole transmission. I towed a Prelude on a trailer to Drop Zone and back (750 miles) and averaged 14 mpg with really bad traffic in Portland and Seattle.
I use straps on the trailer, a Prelude doesn't give you very many places to hook up chains.
Morales8907
yea you should be fine. i had to tow a 80 camaro on a 2000 lb trailer back from indiana to michigan with a blazer xtreme lol went 60 all the way back but it was actually wasnt that bad
droppedtoy
When i hauled with my 95 burban (which has the same 350 and tranny), I kept it in 3rd while towing until i got around 65-70mph then shifted into od. As long as you aren't frequently shifting in and out of od or using od at a real low rpm, it will be alright. Thats why i stepped up to a dually, put it in drive and go!
