Engine Driven Questions
karathos@aol.com's avatar
karathos's avatar
karathos
I was wondering if i run the stock A/C Compressor. How do i adapt my Air lines to the factory lines? Any Info Or Pics would be helpful. thanks.
laiedmazda87
hey,
i gotta question about my stock a/c saden 708 compressor, i ytook it off and put a york on because the saden wouldnt sucking or blowing air... i took the back off of it and all of the pistons are moving and the clutch locks in... any ideal???
nvrdoned50's avatar
nvrdoned50
ive also got a question. i pulled the EDC off a parts truck and on the back are the 2 ports....one says "s" and the other says "d". anyone kno what that means?
olskoolpup
s = suction = air inlet
d = discharge = air outlet
SM
SNEAKY MONSTA
don't know what kind of comp. you have but if is like a stop a/c pump on a newer truck it will not work because it doesn't have a crank case to hold oil like a york the new ones use freon to oil the compressor ,and about the fitting to fit a york you can buy them at lowes or your local bolt supply house just make sure you run a check valve and a good one
ST LayDBurBan's avatar
ST LayDBurBan
someone just post a good picture of your stock mazda ac comp to show him.. thanks lol
nvrdoned50's avatar
nvrdoned50
well the comp is off a 89 isuzu trooper....ill try to have pics of it in a few days
