dual batteries
17 following
suthrn98@aol.com's avatar
dual batteries
low mazda's avatar
low mazda
I had put this in the Off-Topic forum but I know it will get answered here.
How do I run dual batteries? I have like 6 red-top optimas laying around my house, and they are all good, but whats involved in running a 2 battery setup? what all do I need?
simple-pleasurez's avatar
simple-pleasurez
wow july of 04 and no one answered. i was thinking of running dual batteries. anyone know how to do this??
xinsertnamex's avatar
xinsertnamex
i second that question..........anyone with some advice
oldskool84's avatar
oldskool84
Edited: 3/10/2007 2:05:49 PM by Gloworm2oldskool84
What are you going to be running?
Monsterhopper
You can run what is called an isolater it automaticaly chaRGES BOTH BATTERIES BUT OPERATES ON SEPARATES SYSTEMS OR YOU CAN RUN A SOLENOID TO SPLIT THE BATTERIES UP
LOWEST1's avatar
LOWEST1
Use a solenoid if you want one for a bak up. Isolators arent not efficiant there is a power loss through them. Personally I prefer them just wired parralel ++ --. Simple as that
tha mazda's avatar
tha mazda
How do you do that?
thacru78's avatar
thacru78
I'm interested in this also. I want to run a seperate battery for my accesories. With the system, electric fan, and my one AZ my lights dim significantly when all of them are on. I have 2 2farad caps that don't seem to help much. Plus, I might upgrade to an Oasis if my EDC don't work out. Can any provide a wiring diagram. Or maybe a site that can give us a solid answer.
thacru78's avatar
thacru78
Also, If you ran them parralel wouldn't that make it 24 volts. I'm probably wrong. But I know on a old John Deere tractor we have. It uses 2-6volt batteries wired in parallel, to make it a 12 volt circuit.
LOWEST1's avatar
LOWEST1
24V is wiring the batts in series...
for 24v you connect the neg- of on batt to the pos+ of the other Parralel (I know my spelling is wrong) is Pos+ to Pos+ and Neg- to Neg-. I will look for a drawing. DO you want a drawing of a Soleniod? system? Or just 2 Batts?
