moving clutch master cylinder
F
famous_driver
i wanted to see if anybody new how and how hard it is to raise the clutch master cylinder i am going to put either 20 or 22 on my yota so i now i have to move it up. and just needed so help lol
cajuntaco's avatar
cajuntaco
I assume you aren't body dropping it 'eh. Someone told me that if you got a clutch master off of an older toyota it was shorter and would clear.
holcombe347's avatar
holcombe347
^^^ i believe you thinking of the brake booster which will also be a problem if you going with a 20. I think there is a really good thread on what to do with the master cylinder as well as the brake booster and all the different options. Seth flipped his around and reversed the linkage so it works under your dash inside the cab. other people just recess everything back far enough to clear everything and just modify the linkage and pedal assembly to work. i don't want to be the search nazi... but check out the search for those topics. ill try to find them...
holcombe347
this thread might help a little....
i gotta get back to work...
hydroyota
jason fab the clutch master for my truck {the one in the tech} if you need help just ask
F
famous_driver
yea i am going to body drop it thanks holcombe347 that is what i am going to do i appreciate all the help
