Like it? or not?
dubvipers@yahoo.com's avatar
Like it? or not?
dubvipers's avatar
dubvipers
Was just bored, drawing and decided to make a concept of the truck. I got many pictures from the past year too. But i'll try to scan those later!
I even tried a design that reflected the 1st Gen Celicas!!!
I like the idea of the 1UZ swap, even the 3UZ swap! but the 1JZ swap sounds fun too.
I think it looks pretty cool man! Let's see the others!
Do you have illustrator? It would be sweet if you vectorized it and added color to your design
dubvipers's avatar
dubvipers
From what I know, I have Photoshop CS3. Which is similar, correct?
I'll eventually draw it from a 3-D angle, and eventually make a line drawing out of it!
I'll be a tad busy, but I'll vector some later!
Here's Concept 7, my very own sports car design. It beholds a semi-open front fender design, it reflects upon F1 car technology. I intended for a all motor 5L ITB V10, but i guess i drew an intercooler, so make that a Twinturbo'ed Individual throttle body 5 liter V10. Front engine, 6 speed, RWD with LSD. There's too much to explain
This next picture, I've been messing with thIs for a whole school year... you know, drawing in class
But i think it is very radical! You can kinda see the Lexus V8 under the hood
mdevaneydesign's avatar
mdevaneydesign
i like the stretched tires. nice touch haha
dubvipers's avatar
dubvipers
Here's a really "early" 4WD design i did
Soo, that 4WD has a turbo 2UZ with 1UZ rods and gets the awesome dose of VVT-i. so now we have a 4.7L V8 pushing out at least 400-500hp on this truck
But each corner gets massive slicks.... and the transfer case gets a beefed up center differential. So you have all time AWD but the ability to disconnect if you feel like going 2WD only. The reason for the massive slicks is ultimate traction. There is an onboard air system to run the air shocks and the tire pressure system. deflate the tires to about 20psi and watch them "wrap" around rocks and this truck will go up these mountains! Include a dual transfercase with that center diff.... you can leave it in 1st and it'll crawl for you. Literally.
That's quite a bit
