Front Brakes
dmillertitans@msn.com's avatar
Front Brakes
ustarin's avatar
ustarin
On a 94, Is there any upgrade i could do to the front, like bigger rotors (besides wilwood, like a stock rotor from another vehicle) or just a better caliper(like a stock one from another vehicle or something) i could run with stock setup or would upgrading the booster from another vehicle help for better stopping? Would like it to be from other stock cars n trucks because i get a FAT hook up on the parts... Thanks
kdcgrohl's avatar
kdcgrohl
Welcome to the site.
Here is one option
then there is the actual wilwood stuff
and if you'll look through the suspension forum there is a thread about using 4runner calipers.
truck action's avatar
truck action
I posted on this upgrade I did,with all the info I got from ToyMinins.
Uses Wilwood hat, drilled/slotted 12.19" rotor,Toyota 4x4/4-Runner, 4-piston calipers & custom brackets from Mike on ToyMinins
Works very well & is a easy upgrade,cost around $600 to $700 with all parts,which is far less than any kit out there!
I also swapped out to a larger master & double booster for the rear disk conversation that will be next for me!
ustarin's avatar
ustarin
wow completely missed that thread in suspension...thanks and thanks!
truck action
Any questions you can e-mail me,can send you step by step photo's
toyotrick
here is awesome wilwood setup for $800
[url=]Revolution Brakes
They design the kits themselves and run this exact one on their shop truck.
The big reasons I didn't opt for the 4x4 caliper swap is; I didn't want to have to cut brake pads every time I needed them and I daily drive my truck so as little down time as possible is a must.
truck action
This kit was over $1200 when Revolution gave me a quote,so this price is great,also they show a one piece rotor,there didn't have @ the time,so you don't need to use a hat! Should sit in the same plane as stock!
The calipers are Dynlites ,there list for $126 ea.
This front kit is the way to go!!
